Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-29-2004, 10:06 PM
Two_4tee_2NR's Avatar
Two_4tee_2NR Two_4tee_2NR is offline
Send a message via AIM to Two_4tee_2NR
SR20 Fuel
can anyone tell me right quick what the stock SR20 fuel pressure should be and mabye even tell me what it should be at 14 PSI of boost?
western PA's finest....
Teamvoa.com
Old 03-01-2004, 07:33 PM
I<3hks I<3hks is offline
Send a message via AIM to I<3hks
if you have a stoichemetric air\fuel gauge, a fuel pressure regulator and fuel gauge (optional), you can gradully increase your fuel pressure, when your car starts to run rich you can turn the boost up. Normally try to go up in boost increments of 2 psi, when you start leaning out then add more fuel. Caution: it is possiable to be limited to how much boost you can run by the octane of fuel (because of cam duration/lift and timing). Dont think that if you just add more fuel that you are going to solve detonation. Must run on 100,104,110,116 octane fuel, to up the boost any more then what you normally boost @ with detonation on pump gas, on the other hand it is possible to add too much fuel and hydraulic the engine although that it is very hard to do, its possible.
so two_4tee_2nr, if you have your air\fuel gauge, fuel pressure regulator, adjustable wastegate, you can turn up the boost and fuel. get someone who knows what to their doing to listen for detremental sounds, and possibly hookup a scanner or other knock sensing device to detect detonation until your experinced with this sort of thing and you are willing to trust your self in your engine.(but you know this already)
use some common since when tuning your car, make sure that your not trying to make more horsepower then your parts are able to make.
Old 03-01-2004, 08:16 PM
Re: SR20 Fuel
i was trying to accomplish the reduction in the amout of flames out of my tail pipe n the stalling from the vented BOV i figure if i can lean it out a touch i'll be a lil better i gota 255 lpi fuel pump...my buddys a dsm dork he told me to get a adjustable regulator to adjust the fuel pressure...i'll kill the flames....but i talked to a SR20 fan n he told me that its frm the BOV being vented as you can plainley see in my signature =p thanks for ur help HKS!
Teamvoa.com
Old 03-02-2004, 08:47 PM
the only thing that I could think of why you are flaming out is becuase you might be too rich. If your able to monitor and adjust the air fuel ratio go ahead a lean it out a bit to see if it will decrease the amount of flame. Leaner is not always meaner if you dont put enough fuel into the cylinder then its not going to have the amount of gas to make the compression to send the piston back down = loosing power. happy tuning....
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
