Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-29-2004, 09:16 PM
sonya2608 sonya2608 is offline
Angry Key Won't Turn !
I have a 2000 Dodge Neon, and recently I have had to jiggle the key to actually get the ignition to turn. Now it won't turn at all. Should I go to the dealer, and have a new key made? What could be causing the key not to turn once in the ignition?
Old 02-29-2004, 10:55 PM
MStout's Avatar
MStout MStout is offline
Re: Key Won't Turn !
Sometimes the wheel will make it do that...like the tilt and the direction its turned. It happened to my moms Lumina...dont know about Neons though. Try it.
Old 03-04-2004, 02:59 PM
rolnaldo33's Avatar
rolnaldo33 rolnaldo33 is offline
Send a message via AIM to rolnaldo33
yeah, sometimes the steering wheel lock (which is a security measure to make the wheel not turn unless the key is in) will make the ignition hard
Old 03-05-2004, 02:00 PM
MachShockSRT4 MachShockSRT4 is offline
Send a message via ICQ to MachShockSRT4 Send a message via AIM to MachShockSRT4 Send a message via MSN to MachShockSRT4
Yes i have a SRT-4 and my ignition is the same way. So maybe try what they said it should work. If not take it into a dealer.
Old 05-02-2006, 08:39 AM
2bseen 2bseen is offline
i have 2000 neon and Saturday it seems by steering wheel is locked and the key will not turn and i cant unlock the wheel...any help?
Old 05-02-2006, 09:04 AM
SRT-Wannabe SRT-Wannabe is offline
I have that problem with my mom's 02' jetta, i go nuts everytime the wheel locks, it's hell to get that key to turn, the wheel on my 00' neon's never locked before, so i'm hoping that never has to happen to me
Old 05-04-2006, 10:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Make sure the shifter is firmly in park if it is a auto.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-05-2006, 08:33 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Try and rotate the wheel a little before turning the key.
Old 05-19-2006, 05:08 AM
FemaleRacer FemaleRacer is offline
Ok-lets get a few of the obvious things out of the way....is it a brand new or old key? Have you even cleaned your locks or ignition. I know that may sound dumb but you should use lock cleaner in all your locks and ignition as part of your regular "tune up" routine. I know i keeps my keys in my purse set them down on the bar at work, etc. all that crap gets on your keys and into your locks and they start to not line up correctly. I had this exact problem. If this doesn't work a locksmith can come out on location and replace the ignition "barrel" and set it up to match your current keys. Keeping everything one key and and costing a whole lot less than the dealership. Sometimes the barrels crack. Also-is it possible that you have a faulty ignition switch?
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Won't start-steering column frozen-key won't turn amyjodeb Sebring | Sebring Coupe | Convertible 2 04-26-2007 10:47 PM
**HELP** '99 540i won't start/key won't turn new2bimmers Technical 1 10-13-2005 12:59 PM
HELP!! Ignition stuck. Key won't turn Mawgie C/K 1 01-01-2004 08:39 PM
Key won't turn...lubrication? Granite? AshleyAshley General Discussion 2 12-31-2003 12:36 PM
