Old 02-29-2004, 07:00 PM
Mike K Mike K is offline
Send a message via AIM to Mike K
'93 wheels
Will a 5x115 wheel fit on a 1993 cavalier? I know the size should be 5x100 but will it cause any problems? Also, are the stock size 14x6?
Old 02-29-2004, 11:23 PM
SlyBry SlyBry is offline
Re: '93 wheels
No that bolt pattern will not work. That means that the bolt holes will be spaced 115mm apart instead of 100mm.
And yes, the stock wheel size is 14x6.
Old 03-05-2004, 03:34 PM
SmurffCars SmurffCars is offline
Send a message via MSN to SmurffCars
Re: '93 wheels
no acually the stock should be 15x7. And 5x100 pattern. With a tire of 205/60r15Also if you go bigger then that you'll need lower profile tires. I have 17x7 MSR with 215/45r17
Old 03-05-2004, 03:35 PM
Re: '93 wheels
this should help for sizment
http://www.miata.net/garage/tirecalc.html
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
Wheel width/offset help Rooster32 Interior | Exterior | Appearance 0 04-05-2010 10:45 PM
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
96 Town Car: Wierd Prob w/ Steering Wheel Button(s) LieutenantCracker Town Car 6 03-05-2009 12:24 PM
Problem with the steering wheel Ennar Aveo 5 03-03-2009 09:11 AM
