Old 02-29-2004, 04:25 PM
ddum8 ddum8 is offline
body lift kit?
Does anybody know where I can get a 3" body lift kit for a 1991 S10 Blazer that comes with the bumper brackets, a friend said that they make them but I can't seem to find one that comes with the bumper brackets.
Thanks ,Ddum8
Old 02-29-2004, 06:12 PM
godfathers10 godfathers10 is offline
did youtry summit i found a 2" for my 97 from them. summitracing.com
Old 02-29-2004, 06:38 PM
champion69 champion69 is offline
Re: body lift kit?
Hi, last december, i saw at Big Boys two kits sold separately, for the rear axle uses a block (3 o 4 in) to install between the axle and the spring leaf, (no shaft modifications needed); the other kit uses a shims, to set on the eight points between the body and the chassis frame; this option is too cheaper but you dont need change anything; just one safe advise, lifting body or changing dimensions from original, you changes the gravity center, it means the stability of your truck is lost, beware turns at med-hi speed!!, you can change this installing weights (metal sheet at body floor).
Bye.
Body Lift kits chadm_88 C/K 0 04-18-2005 02:45 PM
Body lift kits? cwalk27 C/K 1 01-08-2005 10:56 AM
98 explorer body lift kit??? dgeer Explorer | Explorer Sport Trac 0 12-18-2004 04:34 PM
body lift kit ddum8 S-10 1 10-07-2004 03:25 PM
Body lift kit??? LovelyRJ Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 07-15-2004 08:19 AM
