Old 02-29-2004, 03:08 PM
sLADe781 sLADe781 is offline
Short ram, cold air, ....
How many different types of intakes are there? I know there's a short ram and a cold air but are there other types? Also, which one is the one that would be the most closes in ratio to the stock intake?
Old 02-29-2004, 04:40 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: Short ram, cold air, ....
Closest in ratio? As in how restrictive or what.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 02-29-2004, 05:10 PM
Re: Re: Short ram, cold air, ....
The size and length of the pipe.
Old 02-29-2004, 06:01 PM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
you would have to have one custom made or find someone that makes them
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 02-29-2004, 06:37 PM
Okay, well...I was still wondering how many different types of intakes are there? Short ram, cold air intake, and what else?
Old 02-29-2004, 06:46 PM
ikOnone ikOnone is offline
what do you mean by "short ram"? i hope you do not mean "ram air" because i will just let you know right now that "ram air" will not happen unless you are going speeds that no 3/S will ever go. for the most part, it is a myth but it does happen to a noticable extent if you have a very specifically built intake and you are going at least 350 mph or so.
as for intake options, there are many. you can replace the stock airbox with a k&n or something similar, there are dual intakes that are real nice that i think are sold by dn performance, and there are real nice setups like the blow through and the stuff that comes with an aem and you can get that from driven performance (see sig)
1992 3000GT VR-4 TOTALED
1991 figi blue VR-4 lots to come...
1993 civic hatchback 35-40 mpg of slow reliable daily driver
Old 02-29-2004, 07:18 PM
Re: Re: Re: Short ram, cold air, ....
Short ram meaning the type of intake (I'm assuming it's referring to the type of pipe). I know there are different brands with intakes but I'm talking about the types. For example, I know cold air intakes extends to the bottom of your car. So I was wondering aside from short ram and cold air intakes, what other types are out there? And which one is the most close to the stock as far as the length and size goes (if I'm making any sense!?!). Thanks guys.
Old 03-01-2004, 02:05 PM
N/A-SAVAGE! N/A-SAVAGE! is offline
i think DN is the most close to stock you can get. what it does is replace your stock rubbre pipe with an (aluminum) one, i cant spell so good so your mas is in the same place and you can use the filter of your choice, i think, it might come with its own.
as far as cold air you can find some on ebay that will mork with minor moding (i went this route) that are for the 01+ eclipse gt.
good luck
Old 03-01-2004, 11:19 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
vr4 or sl? vr4 have twinfilter intake, works pretty dang good. supermagaflow intake is another
Old 03-02-2004, 01:39 AM
the best way is to get an arc2 setup u get the computer maf and a huge k&n
Tyler Laabs
Old 03-03-2004, 02:39 PM
switched switched is offline
http://www.store.yahoo.com/tyfoonmot...i30slordo.html
Old 03-03-2004, 02:40 PM
ACTUALLY a cold air intake, not just an open element air filter, replacement for the stock air box sucking in hot air
Old 03-03-2004, 03:01 PM
my friend got a kit for his cavalier from there and we basically had to remake the whole kit,we had to trim the piping etc. that was about 2 yrs ago so maybe they have made progress,but what happens if its raining on this one many cheap kits have no way to not suck up water. water in the engine is no good unless its used for cooling
Tyler Laabs
Old 03-03-2004, 05:05 PM
well mine sits right in front where the fog light should go on the passenger side, and has held up great even in the rain!!
Old 03-03-2004, 08:33 PM
N/A SAVAGE - is there anything holding the piping down securely, so that it isn't flopping all over the place?
also, the filter sits right behind the air vent/fog light on the passenger side? so if you crouch down in front of the car u can actually see it? is this all true?
youve driven in the rain with it and no water got sucked up? thanks
