Old 02-29-2004, 08:25 AM
godfathers10 godfathers10 is offline
suspension?
my 97 s10 blazer measures 3/4 in lower on the passenger side Iput in a body lift all my measurements are equal between the frame and the body its from the frame to the ground that is the off measurement any ideas before i just start replacing things?
Old 03-08-2004, 08:42 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: suspension?
Suspension sagging?Frame bent?My 2 guesss.
Old 03-08-2004, 08:43 PM
Re: suspension?
Tire low?
Old 03-11-2004, 10:19 PM
Pick Pick is offline
Check your torsion bars. One may be sitting lower.
Old 03-12-2004, 07:27 PM
TopDogg TopDogg is offline
Cut .75" off of the high side's lift blocks.
2wd? 4wd?
Have you ever had work done?
Like this before body lift?
Buy the truck used or new?
Tire sizes all the same? Check air pressure.
Measure from ground to each side of rear end. Use a flat spot like bottom of shock mount. See if each side is the same. Then do the same with the front. Get as close to each tire as possible. If rear sides are equal and front side are equal I would beleive that narrows it down to suspension.
I just thought of another idea......... pour a V8 juice in the tank.
Old 03-13-2004, 12:16 PM
jcas1411 jcas1411 is offline
I would check the torsion bar also. Is it missing a bushing. I would go ahead and replace with a polygraphite kit from PST 1-800247-2288
