98 camry relay
anyone know where i can buy one online
Re: 98 camry relay
i dont see the one i need there...im looking for one that will fix my turn lights that just suddenly stopped working.
Ive been reading here that there is a common relay problem but my local parts store say they dont carry them |
Re: 98 camry relay
Relays are fairly standard.Are you sure what you need is a relay and not a flasher? If you can give us a little more info perhaps we can track it down. |
Re: 98 camry relay
well my turn signals dont work at all.....they dont even flash on the inside...all my fuses are fine
and after researching here, i understand it might be a relay problem...honestly i dont even know what relay im looking for, except that its under the hood in the same housing as the fuses...maybe you can walk me step by step |
Re: Re: 98 camry relay
The box under the hood should have everything labeled like this one from 1988: However, I don't see a flasher relay for this year, just a fuse
-Steven 1996 Town Car, Cartier |
Re: 98 camry relay
so what else do u think it would be....
Re: 98 camry relay
It could be the flasher itself,which is a little squarish box located under the dash.
Re: 98 camry relay
well the square under the dash holds fuses...look for the one that says flasher?
Re: 98 camry relay
If I'm not mistaken, the flasher is a silver-colored part that is not in the fuse box. Looks like a small box.
Re: 98 camry relay
The easiest way to find the flasher is to by one at the auto-parts store so you know what it looks like,(the're cheap),look under the dash for the same part.(May have to remove under dash trim).
Re: 98 camry relay
ok will do that soon and keep you posted...would help if someone had a pic.....im geussing its right under the steering wheel or something right?
Re: 98 camry relay
Under the dash in that area.
