Old 02-28-2004, 02:40 PM
Davecamaro86 Davecamaro86 is offline
Send a message via AIM to Davecamaro86
Timing Timing Timing
86 350 TPI. is there any way to adjust the timing on the distribitor without changing timing chain????????????????????
"86" 350 TPI 300hp[IMG][/IMG]
Old 02-28-2004, 03:04 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Timing Timing Timing
hey, that's my hood!!!
Old 02-29-2004, 11:21 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
um, yeah, undo the bolt at the bottom of the distributor, well, loosen it anyway. while a timing light is on the mark, turn the distributor clockwise and counter clockwise, this will change the timing, and is the correct method of setting the timing anyway.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-29-2004, 11:23 PM
89IROC&RS's Avatar
oh and forgot, that there is a plug you have to disconnect. it is a single wire connector, in front of the passenger side firewall, just behind the wheel well. disconnect it, fire up the engine, set the timing, turn the engine off, reconnect the connector. Timing should be set to 0 degrees with that connector uncliped. on a stock engine anyway.
Hard Time Getting Timing Belt On dmfnded Integra 2 05-22-2005 07:53 PM
full time, part time 4wd T-$$ Grand Cherokee | Grand Cherokee SRT8 3 11-09-2004 04:45 PM
'97 Gas pedal sticks from time to time 1997Camry Camry/Camry Hybrid/Vista 14 05-26-2004 06:57 AM
85 2.3L engine timing with timing light Dauber Mustang Talk 0 05-21-2004 06:04 PM
