Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-27-2004, 10:31 PM
Evangelion's Avatar
Evangelion Evangelion is offline
Send a message via AIM to Evangelion
Question 400sb HP??
I need to know the stock hp of a 400sb, came out of a 73 caprice has a 4 barrel stock carb and from what i've read the stock compression is 8.5:1 and that hasn't been changed yet. Just completely guessing a ball-park figure of maybe 200-250ish?
Old 02-29-2004, 06:56 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
I think your right in there, if memory serves....240hp.
But, my memory isn't what it used to be.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 03-01-2004, 04:47 AM
a1supersport a1supersport is offline
Send a message via AIM to a1supersport Send a message via Yahoo to a1supersport
Re: 400sb HP??
Yeah about there. What did you plan on doing with it? Are the last four numbers on the block ID "1911"? That'll make it a 4-bolt main...not that it would be any better than a 2-bolt main. Even though the HP numbers were low, the torque level was good...and torque is usable power.
Old 03-02-2004, 02:33 AM
Evangelion's Avatar
Re: 400sb HP??
Well...im planning on; installing forged 12.1:1 pistons, rebalancing the crank. rebuilding the heads port polish 3angle valve job, pin the rocker studs if they aren't already, upgrading intake,carb, and matching cam. I already have some cheap Mr. Gasket headers that my friend gave me for free ... get an actuall flywheel assembly throw a 5spd manual tranny on it and drop it in a 67-72 chevelle...pump a 150shot of NOS at the tracks.... thats the plan...
Old 03-02-2004, 02:38 AM
leew347 leew347 is offline
Send a message via AIM to leew347
Re: 400sb HP??
That sounds like its gonna be pretty good.
O wait did i say pretty good i meant awsome
red comic sans ms If you cant beat'em dont join'em
Old 03-02-2004, 05:01 AM
Re: 400sb HP??
Woohoo!! Reminds me of my younger days . A few years back I built up a 406 (400, bored out .030), 10.25-to-1 compression, solid cam, roller rockers, camelback 1.94's, Edelbrock Performer RPM, Holley 750 double pumper, Mallory Electronic distributor, MSD-6A box, and fenderwell headers. Backed it up with a steel flywheel and a Muncie M21, and dumped it in my 67 Nova with a 4.11 rearend and M/T 28x10.5-15 slicks. Those tires would not stick because of the 400's torque, and the "shock" of the clutch being engaged. This engine you're building may get a little costly because if you're going to use a 150-shot of nitrous, that stock crank and rods won't take that abuse for long. Aftermarket cranks and rods for this engine aren't cheap. Plus you'll have to find a suitable flywheel that'll work with this engine (the 400 is externally balanced, like a big block), as well as work with the 5-speed you plan on using. Very challenging to say the least. But it can be done. Good Luck
Old 03-03-2004, 07:49 AM
slacker_53's Avatar
Re: 400sb HP??
Good luck with it.........should be kick ass.
-slacker
Old 03-07-2004, 03:26 AM
h3llphyre h3llphyre is offline
Re: Re: 400sb HP??
What type of gas do you plan on running with a 12.1:1 CR? Not anything that can found at a normal gas station.
Do yourself a favor, and get a good set of aftermarket heads. They can be had for cheap. maybe even just buy the edlebrock performer RPM kit.
400SB or 460BB Aces0vr8s General Discussion 2 08-07-2005 04:03 PM
stock hp for ls1 years? reg t/a hp vs. ws6 hp in those years? unicyclemidget11 Camaro Discussions 1 07-14-2005 08:30 PM
headers for a 400sb crazyguy Engineering/ Technical 2 04-27-2004 10:34 PM
400sb from a '73 Evangelion Caprice 1 04-11-2004 07:22 PM
Timing & HP Inatke & HP Blackhaven Taurus | Taurus Wagon 0 10-21-2002 11:15 PM
