Old 02-27-2004, 10:23 PM
dave cordray dave cordray is offline
86 gmc
i installed a target 350 in my 86 gmc in place of the 305 its a generic 350 well it vibrates now and was wondering if it is balanced differently would appreciate help
Old 03-22-2004, 08:59 AM
timberdoodle timberdoodle is offline
Im not familiar with target engines, did u do any of the work urself or is it a crate engine? Check the engine mounts they may need to be replaced also the carb might be makin it run rough, what are you running for a carb? Another would be, if u pulled the tranny at the same time? because then you may get driveline vibration from the driveshaft. Other than that should run almost the same as the 305
2000 GMC Sierra 4wd won't shift into 4 hi or AWD Mike_C Sierra 13 06-08-2011 02:45 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
2002 gmc sierra 3500, 8.1-flashing mil, dies/hard to start Shawn1978 Sierra 4 08-14-2009 08:11 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
2006 gmc sierra hd 7 pole trailer plug peanpone@hotmail Sierra 0 05-02-2009 09:50 AM
