Old 02-27-2004, 07:24 PM
anjoed anjoed is offline
4 wheel drive problem; 1988 F-150
No one seems to be able to help with this- when I engage the 4 wheel drive on my '88 F-150 (manual hubs), in both 4 Hi and 4 Low it "HOPS". This gets far worse when turning the front wheels. Everything seems to engage correctly, but the hopping is severe. This is bad enoough so that when turning sharper turns the truck has a very hard time moving itself. As if it does not have enough power to move itself. It acts (and feels) as though it is running on bent shafts. One person recommended different tires, so the tires are new, but no change. ANY HELP WOULD BE APPRECIATED GREATLY!!!
Old 02-27-2004, 10:56 PM
surgicaltech's Avatar
surgicaltech surgicaltech is offline
Re: 4 wheel drive problem; 1988 F-150
A little bit of "hopping" when turning the wheels is normal,however, "hopping" when going straight is not.
Old 02-28-2004, 02:53 PM
ervinj ervinj is offline
I've got a 89 and mine did the same thing. What happened to mine was one of the lockouts didn't lockin even though the indicator was showing that it was. I replaced both (my choice for both) lockouts and it took care of my problem. Hope this helps.
ervinj
Old 02-29-2004, 12:32 AM
ervinj
Many thanks, friend! I will definitely check that out!
anjoed
Old 02-29-2004, 12:58 AM
ModMech's Avatar
ModMech ModMech is offline
It can also be caused by very stiff U-joints in the knuckles.
Old 03-01-2004, 09:24 AM
97chevyman's Avatar
97chevyman 97chevyman is offline
Could also be caused by a different axle ratio between the front and rear axles, make sure they are the same.
Old 03-01-2004, 10:47 PM
RIGBOSS RIGBOSS is offline
Or It May Have Installed Hopping Hydraulics.. Have You Checked??
;o(
help 1984 F-150 in line 6 4 wheel drive manual edford E Series 0 01-02-2011 04:30 PM
Changing from Two Wheel Drive to Four Wheel Drive mandymelville-love Bongo Friendee 0 04-07-2004 06:17 AM
1988 F-150 4x4 stalling problems Forsaken502 F Series 1 03-28-2004 12:45 AM
all wheel drive or front wheel drive? tran_nsx Integra 7 11-01-2003 09:58 PM
