Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-27-2004, 06:54 PM
Ghost of Duluth Ghost of Duluth is offline
Send a message via AIM to Ghost of Duluth
Compression test info
Just joined the site. Used the search key to try and find this info but only found parts of it. I am doing the famous "Ghetto compression test" on a 94 RX7. I know about the finger over the hole trick but does anyone know the actual gauge specs? I am told that you take the schraeder valve out of a regular compression gauge and watch the spikes as someone is turning the engine over. Was also told that N/A engine specs are around 85 lbs or beter if they are good. I need to know the specs for the 13BREW. I also have a 93 R1 and, though I have been told that the engines are the same and will bolt right in, I wanted to check here.
Thanks for any info that anyone can give me on this.
Need help with Compression Test and Boost Leak Test AbsoluteGTR Eclipse Problem Diagnosis 4 07-16-2006 01:39 AM
Compression test results after almosrt 2yrs of N20 whtteg Forced Induction 21 05-23-2003 02:11 PM
compression test redmanjd Integra 6 11-18-2002 05:31 AM
So I redid the compression test the RIGHT way... habib_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 06-09-2002 04:03 PM
Did a compression test tonight, how'd my car do? habib_88 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 06-01-2002 01:19 PM
