Old 02-27-2004, 07:54 PM
robk5150 robk5150 is offline
help turn signal problem
I am having problems with my 99 Grand Am turn signals. When I turn I use my signals and after the turn or after I turn off my signals, the sound keeps going. I am not sure what it is? It only keeps going for a couple of seconds but every now and then the sound will keep going until I turn the car off. The arrows on the dash work fine its only the sound that keeps going. Appreciate any help
rob
Old 03-01-2004, 12:20 PM
crosa27 crosa27 is offline
Re: help turn signal problem
You may have a bad hazard switch. There's a recall on it right now. See if the year of your car is part of the recall. You can check with your Dealer, or call GM (PONTIAC) AT 1-800-620-7668 or do a recall search here: http://www.nhtsa.com/
Old 03-02-2004, 05:29 PM
Frozenhonolulu Frozenhonolulu is offline
Mine did the same thing. I brought it in on warranty, and they said that it was a bad turn signal switch. It only took them like 30 min to replace it.
02 Windstar - turn signal problem ethanaw Windstar 12 07-02-2016 11:40 PM
turn signal problem? help plz. turbo2nr Jetta/Vento/Bora 1 06-26-2004 04:29 PM
weird turn signal problem HELP!!! geloyaderspiles Grand AM 5 10-19-2003 11:50 PM
turn signal problem! HELP!!!!!!!!!!!!! tydog8 Camaro Discussions 6 10-15-2003 01:34 PM
Please help - turn signal problem siebel_nut1 M Bodies 1 10-07-2003 10:33 AM
