Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 02-27-2004, 05:04 PM
jhard jhard is offline
Firewall in 2002 Galant
Does anyone know where a hole is in the firewall in a 2002 Galant.
Old 03-03-2004, 12:38 PM
ccpeng1 ccpeng1 is offline
Re: Firewall in 2002 Galant
I have a 99 galant and i couldnt find a hole to hook up my subs? i dunno what to tell you but i would love to find out where one is, so let me know
thanks
Old 06-08-2004, 03:21 PM
nick mann's Avatar
nick mann nick mann is offline
Almost impossible. I have heard a rumour that you can get something through the inner front wing and round that way, but can't be more precise than that at the moment. If I find the details I will post.
Old 06-22-2004, 03:32 PM
onlyphases onlyphases is offline
Send a message via AIM to onlyphases
There is a way to run a wire through the upper part of the firewall, on the driverside of the dash but only for a smaller wire. Just drill a hole. That would be neat, clean and quick
Old 06-26-2004, 08:08 AM
nick mann's Avatar
If you drill, be sure that you paint the edges of the hole, and try to find a rubber grommet to stop the wire rubbing on a sharp edge.
Old 07-14-2004, 07:11 AM
Scooby2204 Scooby2204 is offline
Send a message via AIM to Scooby2204 Send a message via MSN to Scooby2204 Send a message via Yahoo to Scooby2204
i have a 95 galant and theres a rubber gromet with a hole on the passenger side just directly behind the engine i dunno if its the same for the newer models but u can check
Old 09-20-2004, 06:51 PM
I found a spot. Under the driver side, all the way to the left and pretty high up there are a bunch of wires that come through. They are wrapped in some black rubber. There is plenty of room to fit a wire for an amplifier. The thing is that it goes down the inside of the side panel. If you open the hood right on the left side where the wire is going there is a few holes that go into that same panel. You can easily fit the wire through there. It's a perfect spot to get to the battery also. You might want a lead wire that is stiff so that you can go straight down the side panel whereas the flimsy amp wire will just fall down.
2002 galant es radio removal keytosilence Galant 1 07-26-2009 03:09 PM
2002 Galant Brake problem milo3169 Galant 1 11-30-2005 06:57 AM
2002 galant keyless entry problem riteshchaube Galant 2 11-27-2005 12:01 AM
2002 Galant performance Knixon71 Galant 1 11-29-2004 10:16 PM
