Old 02-27-2004, 05:12 PM
cbur307736 cbur307736 is offline
87 Pontiac Grand Am Fuel pump
I am having problems with fuel pump fuses that blow as soon as I place a new fuse in place. This problem surfaced about a week ago. After must frustration I discovered that I had a blown fuel pump hose. I replaced with an exact replacement. I had no problems for about 3 days. Blew another fuse. R&R the fuse again. Was able to get car started to get me home from work. Checked the fuse once again as soon as I pulled into my driveway. Turned off the ignition key. The fuse had blown again.
Do I need a new fuel pump?
Also my oil lamp stays lit whether I have the key in the ignition or not.
Any help would be greatly appreciated. Automotive electrical problems drive me batty.
Thanks.
Old 02-27-2004, 05:22 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: 87 Pontiac Grand Am Fuel pump
I believe that the car has switch to kill the power to the fuel pump in the event of low oil pressure...there is a sending unit on the side of the block on the firewall side. The unit is probably bad and causing this problem. But im not sure why the light is on with the key off...you might have a relay that has been improperly wired or is faulty..
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 11:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 03:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
