Old 02-27-2004, 03:21 PM
samwise samwise is offline
Unhappy '96 No Start
Just bought a '96 Suburban LT 350 5.7L; also own an '84. Got love 'em.
115,000 miles on the '96. Had fluids changed to synthetics and just used fuel injector cleaner. Was running fine then wouldn't start and haven't been able to start it since. Haven't tested to see if it's the fuel pump, though it appears that's probably what it is...can't hear the pump when ignition is in "run" position.
Unfortunately, the tank is near full as it was filled (42 gal.) before it had the problem. I've searched and read from this site and others about the fuel pump and how to replace it, and I've got a couple of books on how to change the pump out...Haynes and Chiltons, but what is not clear is how to siphon out the gas when there's a baffle in the way.
How does one get the gasoline out?
Anne
Old 02-27-2004, 07:48 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: '96 No Start
Thats Murphys Law for you in action...fuel pumps only fail right after you fill the tank with gas!
You can slide a 3/8 fuel hose into the filler neck and siphon the gas out into the proper container.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 02-29-2004, 02:00 AM
Re: '96 No Start
The only "baffle" was mine, as it all worked out, got it done...and it was the fuel pump. Thanks to a friend...we got it straightened out. Thanks for your reply.
'96 Camry 4-cyl 2.2L Idle Control Sensor Maulana Camry/Camry Hybrid/Vista 4 03-18-2010 10:29 AM
96 Sunfire won't start jkozie2001 General Discussion 0 03-07-2010 04:42 PM
'96 Window Lift Motor - Driver Rear Intuit Park Avenue 0 08-03-2009 02:24 AM
'96 Starts cold, but takes several attempts when hot tmitty Aurora 5 05-05-2008 09:36 AM
'96 start problem Neutral/yes-Park/no Dan96mustang Mustang Talk 2 04-26-2005 02:05 PM
