Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-26-2004, 11:45 PM
Rainmaker61 Rainmaker61 is offline
Question throttle body temp sensor
I would like to know some of the principles for the throttle body temp sensor.
Old 03-02-2004, 05:12 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: throttle body temp sensor
it measures the temperature of the incoming air with a temperature sensitive resistor. it works with the maf(mass air flow sensor) to calculate the air density coming into the engine. basically the O2 sensors monitor the air leaving the engine and the iat& maf monitor air going in. the computer uses this information along with throttl position(tps) and engine coolant temperature(cts) to pulse the injectors and get a stoiciometric ratio(remember physics) about 14.7:1 . i'm not sure if this was the answer you were looking for it seems every year they add different sensors to make engines more efficient.
MAF sensor or ported throttle body DrRadar Grand Prix 7 04-21-2010 08:40 PM
?? about a throttle body mod thread 4x4chevymanS10 Performance 4 09-20-2009 10:32 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 06:11 PM
throttle body temp sensor Rainmaker61 General Discussions 0 02-26-2004 11:40 PM
Throttle Body, TPS Sensor damir831 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 10-25-2003 04:27 PM
