Old 02-26-2004, 03:13 PM
gbaber gbaber is offline
93 LeSabre Radio Swap......
Hello,
Can anyone help with instructions on removing the original radio on my 1993 LeSabre? Cant see how the dash faceplate comes off and dont want to break anything in the process. Thanks in advance.
Best regards,
Grant Baber
Old 02-26-2004, 08:36 PM
93ltd 93ltd is offline
Hello,
You have to pull off the faux wood trim panel that surrounds the climate control system, then you will be able to see some of the attachment screws. also you must pry out the ac vents on the trim panel, there you will also find some screws the glove box and all will have to be removed. then you will have access to the radio
1997 LeSabre Radio swap Need Info RASCARS LeSabre 4 05-23-2006 12:56 AM
94 Lesabre radio removal tgif1985 LeSabre 2 02-01-2005 02:16 PM
Anyone? - 2000 LeSabre Radio avatar307 LeSabre 3 12-13-2004 09:52 AM
2000 LeSabre Radio Antenna Connector avatar307 LeSabre 2 11-28-2004 12:17 PM
1989 LeSabre radio problem ipo LeSabre 1 10-10-2004 09:42 PM
