Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 02-26-2004, 08:49 AM
Vanrunner Vanrunner is offline
Question Electric Door Lock Problem w/2000 Montana
I recently purchased a 2000 Montana. It did not have a remote for the keyless entry. I purchased two remotes from keyless ride.com programmed them and all was well.
Well being as tight as I am I found two remotes for 25% of the cost I had paid for the others on Ebay. I had a 30 day money on the first two so I sent them back and bought the remotes on Ebay.
I programmed these next two remotes. That is when I immediately started having problems. I would program one and the other remote would stop working and vice versa.
Now, the locks won't work with the door buttons or the remotes. You can hear that it is trying to lock/unlock but it doesn't.
I am sure there is a limit on number of remotes that can be programmed. So if the van had 1 or 2 remotes before I bought it and now I have programmed 4 it could be that I am trying to program 6 remotes.
The second set of remotes have all the same numbers as the first two. The second set of remotes came from two different sources.
Question: Is there a way to UNlearn a remote or reset the system so I can start all over. I think I have really confused the poor little BCM with all of this progamming.
Please help!
flashing interior dome lite and electric door lock problem berniescout Blazer 11 05-06-2006 06:55 PM
99 Tahoe electric door lock problems jonny54 Tahoe 1 12-16-2004 09:28 AM
91 electric door lock problems kennyg5 M Bodies 1 09-11-2004 05:50 PM
electrical door lock problem joemama152 Cutlass Series 0 03-24-2004 02:14 PM
Electric Door Lock Problems adavis Camry/Camry Hybrid/Vista 3 07-24-2003 04:08 PM
