Old 02-26-2004, 07:15 AM
Magik Si's Avatar
Magik Si Magik Si is offline
How Do I Know...OBD?
How do I know if my 90 Civic Si is OBD-I or OBD-II...I'm just starting to get int othe "electronic" learning of my car and am wondering...this is the "brain" of the car so I want to make sure I'm mind melding with the right equipment.
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 02-26-2004, 07:44 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: How Do I Know...OBD?
it goes by years...
88-91= OBD0 (technically it is a version of OBD1, but its generally called OBD0)
92-95=OBD1
96-00=OBD2
SOLD!
Old 02-26-2004, 08:20 AM
Magik Si's Avatar
OBD-0??
Weird...never even hear that one before...so...if I bought a "scanner" would it be for OBD-1?
Jason
Old 02-26-2004, 08:25 AM
slyw/fbpsi's Avatar
slyw/fbpsi slyw/fbpsi is offline
no it'll be odb0 like he stated earlier, unless you want to convert your car to odb1 or odb2.
Sly
Gotta catch me first
Old 02-26-2004, 08:33 AM
Magik Si's Avatar
Is there a way to verify what it it "actually" is? For example is it "marked" on the unit somewhere? Is there a way to tell...want to know for sure so I'm not starting blind...
Jason
marked001's Avatar
Moderadur
Originally Posted by Magik Si
OBD-0??
Jason
I'm pretty sure that only OBD2 and up can be scanned...OBD0/1 are not all that sophisticated
SOLD!
Old 02-26-2004, 08:39 AM
slyw/fbpsi's Avatar
Jason
Dude, it's common knowledge that 88-91 civics are odb0 92-95 are odb1, 96-98 and odb2a and 99 and up are odb2b. the scanners only work on odb2 cars.
Sly
Old 02-26-2004, 08:40 AM
Magik Si's Avatar
Ok...this may be a dumb question...but...
Obviously OBD-2 is better than 0 & 1...so that said, how difficult is it to convert my car to "2" from it's existing "0 but sorta like 1"??
Jason
Old 02-26-2004, 08:44 AM
slyw/fbpsi's Avatar
Jason
Who said odb2 is better that odb1? if that was the case why does hondata only deal with odb1? to convert to odb2, you need to get the conversion harness from locashracing and an odb2 ecu.
Sly
Old 02-26-2004, 08:55 AM
Magik Si's Avatar
Re: Re: How Do I Know...OBD?
Dude...obviously it's not THAT common knowledge because I didn't know it...AND like I said I'm JUST beginning to learn the 'electronics' of my car...
If the scanners only work on obd2...then why can you buy obd1 scanners??
So what is the primary difference between obd0 and obd1?? And is there a "better" thing to have?
Jason
Old 02-26-2004, 09:03 AM
slyw/fbpsi's Avatar
Re: Re: Re: How Do I Know...OBD?
Jason
Why do you need a scanner anyway? you can check any codes with the jumper harness by the ecu?
Sly
Old 02-26-2004, 09:18 AM
Magik Si's Avatar
Re: Re: Re: Re: How Do I Know...OBD?
HUH?? I have no idea what that means?? I don't want just codes...I can get those by counting the "blinks". I want what Honda charges me $57.50 for! (and then tells me nothing by the way).
Jason
Old 02-26-2004, 09:21 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
alot of dumb shit is being flung around this thread so lets clear it up.
you can only buy scanners for OBDI and OBDIIa/b motors. they have a connector under the dash where you plug the scanner into, there is no scanner input on our OBD0 cars.
OBDII is hard to convert to, cause you need to add extra sensors to the motor, as well as a new ecu and alot of wiring. Higher OBD's are better cause they tell more as to whats wrong with your car, its easier to pinpoint problems. they are also alot easier to fix, most problems can just be connected to a laptop and adjusted.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-26-2004, 09:41 AM
Magik Si's Avatar
THANK-YOU!
Now...what is the best way for me to "learn" what does what "electronically" with my OBD0 car?
Jason
Old 02-26-2004, 09:44 AM
marked001's Avatar
Moderadur
..if you want to learn the inner workings of the pm6 ecu... check out www.ghettodyne.com ...
SOLD!
OBD Plug Location on 85 Crown Vick ezh10111 Crown Victoria 2 06-30-2010 03:32 PM
HELP on some OBD II Codes royto Stratus 2 08-09-2009 07:14 AM
how know sir tranny ? hany '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 12-07-2005 11:09 AM
dumb question but need to know obd question civicdemon91 '88 - '91 Civic | CRX | Wagon | Shuttlee 1 01-13-2005 12:34 PM
