Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 01-03-2002, 01:41 PM
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
Stock Amp Location?!
I've got a 99G20 with the stock Bose [I guess]. I was wondering if anyone knew where the stock Bose Amplifier was located? Thanks.
Newbie
Old 01-03-2002, 02:31 PM
GoldP11 GoldP11 is offline
The stock amp is in the trunk. On the underside of where the speakers are mounted.
Adrian
1999 Infiniti G20t
2002 Ellsworth Id
Old 01-03-2002, 02:57 PM
Thanks...does that mean each speaker has its own amp?
Newbie
Old 01-03-2002, 03:26 PM
no all the speakers are connected to that one amp. I unplugged the amp and my speakers didn't work after that, so I had to plug it back in and it worked again.
Adrian
1999 Infiniti G20t
2002 Ellsworth Id
Old 01-03-2002, 04:35 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Yep. The radio is connected to the amp which is connected to the speakers. Disconnecting the amp wouldnt help you get sound to the speakers now would it?
Old 01-08-2002, 06:22 PM
95_G20_P10's Avatar
95_G20_P10 95_G20_P10 is offline
ur getting your signal from the amps thats why.
Old 01-08-2002, 11:36 PM
Just so you guys know...
I "replaced" the BOSE amp with my Kenwood PS-500F amp...it sounds pretty dam good too. The bose speakers are 2 ohms which makes it extremely loud with the gain only at 1/4 of the way on my amp...good stuff when you're limited on funds.
Newbie
Old 01-08-2002, 11:46 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
I think each one of those bose speakers is being powered by its own kind of "amp" located right on the speaker. That might be another reason it is loud. No worries though, sounds great, right?!
Troy P.
My "pretty-much-stock" G20
:apoke:
Old 01-09-2002, 10:31 AM
nope that's the only amp. It's because the BOSE speakers are two ohms. The only reason why I don't want to replace them...but I'll wind up getting new ones eventually.
Newbie
Old 01-09-2002, 03:57 PM
frogg's Avatar
I know alot about the Bose system because I went through a lot of hell trying to get it working with a new head unit and amp.
In the end, I just ended up swapping out the whole system!
Also, about the amp on every speaker (maybe its diff. on a 2000), but there should be 3 connectors on the speaker if I remember correctly, not 2 like a regular speaker.
Troy P.
:apoke:
Old 01-09-2002, 04:16 PM
Hmm...luckily for me the 99 was a drop in fit. I used ALLDATA because my brother's a mechanic so he's got free access....good stuff.
Newbie
Stock Radio for installing Subs/Amp? robkule422 Car Audio 8 02-01-2011 07:29 PM
Where is the AMP located at? HondaSi88 Villager 2 02-05-2005 09:23 PM
99 suburban stock amp location pbond13 Suburban 5 01-14-2005 10:46 PM
Rear Amp location mattd860 '94 - '01 3 11-09-2004 10:01 AM
ford amp location reallybigfuzzy Continental 2 03-14-2004 11:20 PM
