Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-25-2004, 05:44 PM
cisco1 cisco1 is offline
88 ranger trany problem
I have a 1988 ford ranger with an a4ld auto transmission, the forward gears work fine, but the reverse slips , sometimes cannot backup at all,the fluid level is ok, what do you think? Do i need new bands.hope some one can help. took it to a trany shop and naturely
they said $1,200
thanks ciscok1
Old 02-26-2004, 12:15 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: 88 ranger trany problem
Do they not seem respectable or trustworthy? Maybe you should try another shop? Is that $1200 complete rebuild or patch. How many miles on your rig? Sounds like the direct clutch isn't holding well. Which can be attributed by many things. Like excessive clutch pak clearance, excessive band clearance, low boost pressure in rev,worn valve body, stuck shift valves, side loading of direct clutch drum, center support sealing rings, and so much more. 95% of the time there is no cheap fix for these, or any tranny for that matter. You can pull the hose off the vacuum modulator, if ATF runs out, then renew it. That usally only effects the shift from 2nd to 3rd gear(direct). But give that a shot first. Don't waste any money on a service or flush. Reverse band not adjustable. Good luck!
1994 Ram air bubbles in trany fluid mrkabokieman Ram Pickup | Ram SRT10 0 07-21-2009 11:29 AM
1993 ranger has issues dimwittcaddy Ranger | Courier 3 04-23-2009 09:46 PM
96 AXOD Trany problem s wagon Sable 2 01-19-2005 06:17 PM
clutch/trany problems banks_37 Cherokee 4 10-13-2003 11:18 AM
trany problem, dealer warrranty ends soon!! rjones2001 General Discussion 5 06-01-2002 07:34 PM
