Old 02-25-2004, 03:47 PM
Hybrid1990crx's Avatar
Code 17 Vehicle speed sensor
My speedometer isnt working. I check the speedo cable and it seems to be in the trans correctly. I pulled the carpet back to see what code was flashing and its a code 17, which according to www.4thgenerationcivic.com, is the vehicle speed sensor. Would a broken speedo cable cause this? Thanks guys.
Old 02-25-2004, 04:39 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: Code 17 Vehicle speed sensor
don't forget, it can easily pop out also from the back of the speedometer. pull of ur cover on the gauge cluster
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 02-25-2004, 09:04 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
no jordan, that only happens to hooptie cars like yours! haha, kdding. Yea, check what bambam89lx just said. Make sure the clip holds it down. Also, try take out the speedo cable and then try putting it back in.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 02-26-2004, 05:57 AM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
its a broken speedo cable, this has happened to me a couple of times. replace the cable
Old 02-26-2004, 06:43 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
ditto, mine snapped when i was driving, scared the shit outta me cuz i was doin 80 km/h looked at my speedo and the speed was droppin untill it hit 0, i was really confused, turns out the cable inside snapped
Old 02-26-2004, 08:22 AM
slyw/fbpsi's Avatar
slyw/fbpsi slyw/fbpsi is offline
yeah mine broke on me as well, going like 80 mph, just go to the dealer and get another one, took like 30 minutes to fix.
Sly
Gotta catch me first
Old 02-26-2004, 08:10 PM
Masta's Avatar
mine works...the needle shakes like a mother...i'm getting the ecu code 17 also.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Old 02-27-2004, 08:15 AM
slyw/fbpsi's Avatar
Re: Re: Code 17 Vehicle speed sensor
my needle was shaking at first too, before it completely broke.
Sly
Old 02-27-2004, 08:49 AM
Masta's Avatar
i dont' get it, mine was working before the swap.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Old 02-27-2004, 08:56 AM
slyw/fbpsi's Avatar
I feel you man, everything was working before my swap, but then I had to change my brake master cylinder, vss sensor, tie rods, main relay (twice), ignitor(twice), thermostat sensor, bleed my radiator, ignition coil (three times), starter (three times), spark plugs, and rotor. And I've only had the swap completed in january.
Sly
Old 02-27-2004, 09:02 AM
bambam89lx's Avatar
AF - Advisor
Shit man, I hope it was worth it...seems like you coulda put 3 engines in that car by now.
Old 02-27-2004, 09:05 AM
slyw/fbpsi's Avatar
Re: Re: Re: Code 17 Vehicle speed sensor
don't even count the money spend trying to get the a/c to start working again only to find out the plug were not reconnected after the swap, alot of the stuff was under warranty so, no money came out of my pocket for the second or third time.
Sly
Old 02-27-2004, 12:50 PM
Stop highjacking my thread you bunch of pirates!
Old 02-27-2004, 06:42 PM
Masta's Avatar
haha. i fixed my speed sensor problem, it wasn't down tight. now the speedo doesn't shake any more when i'm driving now...gotta reset the ecu...if only i remembered how...
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Old 02-29-2004, 05:59 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Hazard fuse
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
