Old 02-25-2004, 10:52 AM
bmw2002nut bmw2002nut is offline
performance resistors
I see alot of performance resistors for sale very cheap and advertising up to 20 hp gains. What it looks like is just a resistor that you put in the Air Intake Flow sensor plug that tells the ECU that the engine is under more of a load than it actually is, thus advancing the timing and adjusting the air fuel mixture. They sell these for all types of cars with fuel injection and i would like to hear from anyone that has tried one or knows more about them. Im kind of hesitant to put one on if im not sure what all the effects it will have are. Thanks!!
Old 02-25-2004, 11:18 AM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Re: performance resistors
Save up and buy an intercooler instead.
Old 02-25-2004, 12:41 PM
fast98gtp's Avatar
fast98gtp fast98gtp is offline
Send a message via AIM to fast98gtp
there's something on zzperformance.com that talks about that. you should check it out before buying it.
Old 02-25-2004, 01:22 PM
99_gtp 99_gtp is offline
you can do that i have done it and it helps a little i use a 33k resistor i think but just save up and but something usefull
being blown is better than being thrown
Old 02-25-2004, 10:47 PM
Re: Re: performance resistors
Here is the information from ZZP's site:
Air temp modules
An air temp module is simply a fancy packaged resistor made for people who don't know any better. Companies like SLP offer this for ~$25 and many are lured into purchase by it's low price and ease of install. It tricks your PCM into thinking it's cold outside and therefore "optimizes timing". In reality it does little to nothing and cannot change commanded timing by more than 1 degree (and that's on a hot day where you probably can't use the extra 1 degree of timing anyway). Save your money and don't buy it. If your curiosity gets the best of you, buy an 8k resistor from Radio shack and save $24.50
Old 02-26-2004, 08:12 PM
Thanks for the info yall. It is much appreciated. They are goin on ebay for between 5 and 25 bucks. For a .50 cent resistor, thats pretty good mark up.
Old 02-27-2004, 09:31 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
IT is important what the ECU(PCM) percieves as input but more important is the atmosferic conditions. What is the use to advance the timing when the day or the car or intake air flow is too hot. Instead of getting more timing you will get more KR since the car will knock more because it might be injecting more fuel that would detonate quicker than expected due to the higher temps. The PCM will then KR to protect your car. More KR means less power
