Old 02-25-2004, 09:36 AM
IFallsRon IFallsRon is offline
Sub fuel pump motor
I recently purchased a 98 LT with 113,000 miles. The wife called to my attention a buzzing noise from the rear end. Upon inspection, it sounds like a small electric motor behind the license plate. I'm guessing it's the fuel pump. Does the fuel pump run all the time and make a noticeable buzz?
Old 02-25-2004, 09:48 AM
dirty dan dirty dan is offline
Re: Sub fuel pump motor
Fuel Pump should run just a few seconds when you first turn the key on and will be on anytime engine is running. Do you have an aux heater in the rear??
Old 02-25-2004, 02:28 PM
TK 14 SS TK 14 SS is offline
I'm in the same boat- '98 LS with 108k miles and the fuel pump whines/buzzes. From all of the resaerch I've done this is "the excepted norm" on our model years and a few others. from what I've read etc... it seems that well over half of them do it. I was all ready to get a new pump and replace this one but am fully convinced that it is "okay" and who's to say if I replace it the new one wouldn't be the same way; especailly at a "dealer cost" of $395+ (part# 25314341, Delco# MU132)for the pump alone, but there are/were some on Ebay etc... a little cheaper
Troy
P.S. If that's not a good enough answer for you then search using the key word "pump" in this forum alone and you can get more detailed elsewhere, if it helps put your mind at ease.
Old 02-26-2004, 05:54 AM
CalessaSSracer CalessaSSracer is offline
its NORMAL !!!!! they are just a bit loud
Old 02-27-2004, 03:52 PM
2000BurbOwner 2000BurbOwner is offline
Send a message via MSN to 2000BurbOwner
Re: Re: Sub fuel pump motor
I have a 2000 and it does it on that too. I guess it depends on how loud it is. At the suggestion of someone on here, I replaced the fuel filter since a clogged filter can add to the strain on a pump and cause it to wear out faster. Also, I've been told not to let your fuel tank get below 1/4 tank. that's just a safety precaution because if you run your tank empty, you'll burn up the fuel pump for sure.
Old 07-08-2004, 06:04 PM
Unhappy Re: Re: Sub fuel pump motor
damn fuel pump went out yesterday
Old 07-09-2004, 11:33 PM
Mintman Mintman is offline
Talking
www.rockauto.com has the fuel pump for $245.00. And it's an AC-Delco!!
Old 07-14-2004, 06:23 PM
i just changed the pump 5 days ago, but the FUEL GAUGE still reads full! i was really carefull putting the new pump in...what gives?
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
