Old 02-25-2004, 05:47 AM
joesix joesix is offline
Spark Plugs
I just put accell 300+ thundersport wires on my 93 civic but i'm still running the standard NGK plugs, I was thinking on upgrading to NGK iridium or Bosch platinum +4 or should i stick with regular NGK plugs. I'm new to imports and know next to nothing about them.
Old 02-25-2004, 06:35 AM
thepolishmafia1337 thepolishmafia1337 is offline
Re: Spark Plugs
i would stick with the regular ngk. the spark plug determines the draw on the coil. if you put a higher draw spark plug on with a stock coil you run the risk of running the coil on the ragged edge and burning it out faster than usual. so if you up grade the plugs upgrade the coil as well. the plus fours have caused more problems than not for me. just thought id pass that on
