Old 02-25-2004, 05:07 AM
Dakota280 Dakota280 is offline
Help with newbi system
Anyone tell me if this will be a good start for my system
I have a 95 caddy eldorado, didn't touch the speakers yet, just going for the subs.
alpin deck, can't remember what kind off hand, came with the car.
2 audiobahn aw1206t dual voice coil, 1100 rms subs
1 audiobahn a8000t amp, 800@2 ohm rms
1 audiobahn 1 farad cap.
Got the whole setup for around $500 new with 1 year warranty so don't diss me too bad,I'm not a rich guy, puttin alota faith in audiobahn.
if anyone can help me on a box be much apreaciated.
Old 02-25-2004, 11:20 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Help with newbi system
if you don't care about how your music sounds, it would be a good system. I imagine it can get very loud
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 02-25-2004, 03:01 PM
Think the amp will be enough to pump these subs for the time being, or should I start saving for another one so I can run one to each sub?
Bought a damn box and they don't fit either, mags are too big for a slanted box
Old 02-25-2004, 05:48 PM
sr20de4evr's Avatar
those subs are dual 4ohm?
in that case, you're only sending 200 watts to each speaker. If you were to get another amp, you could send 800 watts to each. I'm not going to tell you what you should do, because if I were to do that you wouldn't like my answer, but you will get 4x the power by getting another one of the same amp.
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-01-2004, 11:47 PM
benny27 benny27 is offline
Re: Re: Help with newbi system
just put them in the other way so the mags are out of the box they look good like that and will not sound one bit different.
and then revers the polarity of the speaker connections.
Old 03-01-2004, 11:57 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
WRONG WRONG WRONG
If the subs are dual 4 ohm then the amp will do fine ..it is rated at 800w x 2.. each sub can be wired in parallel to create the 2 ohm load that it is rated for...
Dont tell newbies how to do stuff if you dont know yourself..
Old 03-02-2004, 12:08 AM
here is a pic of how to wire up you subs red is positive and black is negative.
hope it helps
Old 03-02-2004, 04:26 PM
sr20de4evr's Avatar
Originally Posted by xjoeharperx
WRONG WRONG WRONG
Audiobahn a8000t
Amplifier Type: Mono
RMS Power: 400W x 1 @ 4 ohms
RMS Power: 800W x 1 @ 2 ohms
*cough*
thanks....
maybe you should read a little more before bashing someone who does actually know what's going on
'01 Black Sentra SE
'05 Silver WRX STi
Old 03-03-2004, 10:29 AM
my bad..lowest ohm load possible : 2.75
