Go Back   Automotive Forums Car Chat > Ford > Probe
Old 02-25-2004, 03:13 AM
usnaotuck usnaotuck is offline
1995 ford probe se 2.0L cold air intake problem
I just installed a basic cold air intake kit on my probe, and now my car doesn't run like it did with the factory air intake system on it, has anybody had this problem, when I push the gas down to accel. the engine bogs down and I don't get any power. Is there any thing I have to do after installing this new air intake. The new air intake just bolts on to my M.A.F. sensor. Please help!!!!!!!!!!!!!!!1
Old 05-24-2004, 07:41 AM
net1it net1it is offline
Send a message via MSN to net1it
I have a 2.5 With the same problem
Have you figured out what caused this. I just bought a probe and it is doing the same thing and I noticed that it has an aftermarket air intake system.
Old 05-29-2004, 04:57 PM
doucmehu's Avatar
doucmehu doucmehu is offline
Re: 1995 ford probe se 2.0L cold air intake problem
did you remember to hook up the MAF sensor again?
VeeDub!!
Name that song - "Pull on the trigger and the nightmare stops"
Old 06-11-2004, 02:31 AM
DysProbe DysProbe is offline
Go here
Like he said check to make sure you plugged the sensor back in to the VAF, also check for cracks in the older throttle body elbow tube. Is it a 2.0 or 2.5? Bah, nm, just read it's a 2.0. I have a 2.5, so can't really help you much.
If you get a chance check out www.probetalk.com and use the search forums, they have all the answers to anything you need, that is if you don't get it here.
Old 06-17-2004, 01:05 AM
xtreme2 xtreme2 is offline
Send a message via AIM to xtreme2
Yea. did you plug the IAT in where it should go? it's the sensor that was in the back of the airbox... it should plug into a hole about halfway down the tube...
Also, did you remember to put the gasket back in? It's the brown paper-like stuff in between the intake and MAF...
Go to Probe-Enthusiast.com and ask the question. I am sure someone can help you...
Old 08-13-2004, 09:28 AM
bcd81 bcd81 is offline
Send a message via AIM to bcd81
cold air intake fix
what you need to do is to replace the mass air censor I have 95 se with a homemade intake with electric blower and thats what i had to do i hope this help
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
