Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 02-24-2004, 08:27 PM
jasonj jasonj is offline
1992 dodge aries.drive belt squeal?
1992 aries 2.5L sohc,no turbo.The drive belts squeal like crazy even after replacement of the belts, pullys etc.the belts i'm sure are tight enough.however if i spray them with wd40 the squeal goes away momentarily. any ideas??losing money!
Old 03-03-2004, 03:44 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Which belt is squealing? Is it the serpentine belt or the v-belt?
Old 03-30-2004, 03:17 PM
DaYtOnAt2's Avatar
DaYtOnAt2 DaYtOnAt2 is offline
Send a message via AIM to DaYtOnAt2
Dry bar soap will be a longer term cure for noise. CAREFULLY with the engine running lightly drag the soap on the belt. The bushings that hold the upper mounting bolt on the alternator are probably bad allowing the pully to "cock" to an angle and voila! it sqeals...
Small, quiet squeak from fan/drive belt RAMpage92 Ram Pickup | Ram SRT10 1 11-20-2009 06:01 PM
How to put the drive belt back? serge_saati Windstar 9 10-25-2009 07:55 AM
99 Astro Van AWD belt squeal grampsVVV M Bodies 2 08-21-2009 11:39 AM
1998 Dodge Caravan AC Belt Squeals bcollins031 Caravan | Voyager 5 07-22-2005 09:36 AM
