Old 01-03-2002, 08:31 AM
SpOoKsDaWg805's Avatar
SpOoKsDaWg805 SpOoKsDaWg805 is offline
Question Tips on painting windows?
I was wondering if anyone had any tips on how to paint around the window trim black without having the paint run. In other words the part around the window that is usually black. Do I paint the inside or the outside of the window??
Old 01-03-2002, 08:53 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I mask it and use an air brush. Like Dan does I give it a nice thin coat a first then a couple of medium coats untill it's nice and dark. I think I've really perfected it on my RX-7 and S2000. Windshields should be painted on the inside.
For brush painting, after masking, try a thin coat then get progressivly thicker until you get teh desired effect. Maybe thin down the paint for the first couple coats.
Old 01-03-2002, 09:11 AM
primera man's Avatar
"P-Man"
Only use Tamiya masking tape as it will not allow the paint to bleed under the tape. It will give you a perfect line when done.
Other types will
View All My Models Here.
Old 01-03-2002, 10:36 AM
Thanks for the tips guys.....guess I need to pick up some Tamiya masking tape.
Old 01-04-2002, 05:54 PM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
How you cut the mask and do not scratch the windshield?
The same when masking over painted surface. Knife leaves scratching marks on it
Current project: Tamiya Porsche 959, red
Old 01-04-2002, 06:11 PM
Guiddy's Avatar
Guiddy Guiddy is offline
You have to cut the tape to shape off the plastic!
As for other areas, yes it does scratch the surface, but you don't seem to notice as it fills with paint!
Old 01-04-2002, 06:17 PM
G-Forces's Avatar
Banned
Originally posted by awaken1973
[b]How you cut the mask and do not scratch the windshield?
For the clear windshields I use a technique I came up with myself. I put enough tape on the 'front' of the windshield to cover the area you'll be masking. Then I take an overhead marker and outline the masking area on the back. Trace the area on the masking tape with a pen. Taking your time will yield better results. Then transfer you tape to a non-sticky surface and cut out the mask to your traced outline. move the tape to the windshield now.
For black window surrounds I mask as closely to the surround as I can. Then using a new sharp knife and very lightly cut out anything hanging over. Not using too much pressure and a sharp knife is key.
If anyone has a better technique for masking the windshield I'd like to hear it.
HOW TO....Paint window frames and rubbers primera man Car Modeling 38 12-06-2009 05:30 AM
How to take out a rear side window from a 96 honda civic Danthony_20 '96-'00 Civic 1 11-05-2009 11:38 PM
Interior paint summary/tips... Painting plastic, trim, bezels, vents, dash etc number50 Appearance: How To... - FAQs 5 10-31-2009 01:36 PM
new tips - Painting with Nail Polishes hrmodeler Car Modeling 2 09-02-2002 08:12 PM
