Old 02-24-2004, 07:42 PM
96Maro 96Maro is offline
Worried about my V6 ....again.. plz help
OK i have a new motor in my 96 camaro. It has about 20,000 miles on it. Tha last v6 had bad lifters then a rod messed up or something so i had to get a new motor. This one has still has minor problems. Not with the motor but just little things. The problem is it seems to hesitate. Say if i are sitting still and i get on it to where it shifts around 4,000 rpm it is smooth and fine. But when i am crusing about 30-40 and i get on it to 4,000 rpm it seems to hesitate a little usually either one - two times. I am just worried about it. I love my car but it has been nothing but trouble since i got it. Do any of you guys know what this might be and what to do to fix it? Just trying to get my baby running right.
Old 02-24-2004, 08:59 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Worried about my V6 ....again.. plz help
might be a trans problem. you can have it diagnosed for a problem. id check your fluid level, and color and smell. if its black, or smells burned, you got issues, if its low, add some. if that dont fix it, or address the problem, id have it looked at.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 02-24-2004, 09:01 PM
89IROC&RS's Avatar
oh and im assuming that its an automatic trans. if its a manual, the problem could be computer aka PCM related. or any number of sensors, you would have to have it diagnosed by a tech 2 to monitor sensor inputs and look for something abnormal.
Old 02-24-2004, 10:03 PM
its an automatic. The transmission is new too. Its only got 20,000 miles on it and it was put in a few weeks ago with the engine.
Old 02-25-2004, 03:12 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Mine once hesitated because of the transmission, be careful where you take it though, these guys are real scammers. But also check the plugs and wires.
Old 02-25-2004, 05:35 PM
89IROC&RS's Avatar
actually having read the post further, are you in overdrive when you are cruising at 30-40mph??? cuz if you are, it might take a second to shift out of overdrive where from a stand still your in first gear already, what i normaly do is drop down from OD into D before i stomp it, the difference is drastic. try doing that and see if it solves the problem.
Car Alarm Issues..again,plz help lilsweets3138 Non-Performance 0 11-23-2010 06:20 PM
1994 Dakota run's like as* plz help me out 3.9 magnum plz help asap (busing sucks) starpuss Dakota 1 04-09-2006 05:52 PM
Questions About Fto? Need Help! Plz FTOway2GO FTO 1 12-13-2003 12:28 PM
i have a question about body kits...plz help civic2001albright '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 10-09-2003 06:45 PM
