Old 02-24-2004, 07:02 PM
jsnowbordr47 jsnowbordr47 is offline
Keyless entry systems question
Was the keyless entry system standard on LT trim in 1995, or was it another special option package above the standard LT trim?
Also does anyone know how much it would cost to install one of these keyless entry systems on my suburban, or would it just be better to go and buy an aftermarket alarm system?
Old 02-24-2004, 10:52 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Keyless entry systems question
My guess is that it was still an option even on the LT's. We had a Tahoe ed. S-10 Blazer that didn't have OEM keyless. Do a search on it here, there's a way to read the codes to see if it had it. Aftermarket ones are pretty simple. I like DIrected Electronics.
Old 02-27-2004, 04:02 PM
bcleeper bcleeper is offline
A quick and easy way would be to put the system into keyless program mode. There are several posts out there detailing how to program keyless entries so I won't attempt to repeat it here and get it wrong. It is pretty simple to do though. All you need is a paper clip and the right pin numbers to jumper on the jack under the steering wheel for the diagnostics module.
Old 02-27-2004, 08:55 PM
Yeah that might be but only if it came with keyless from the factory. I guess he could try the program sequence first to see if it will work. I guess that if it responds then it has OEM keyless module.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 05:46 AM
'09 Corolla KeyFOB, keyless entry programming Question btrolla Corolla/Matrix/Voltz 1 09-03-2010 01:00 PM
Nissan Sentra keyless entry module location serge_saati General Discussion 2 06-26-2010 11:03 PM
remote keyless entry problem smity9089 Intrigue 0 04-14-2009 12:45 AM
Question on keyless entry system RUFLYF Blazer 0 01-02-2004 01:05 PM
