Old 02-24-2004, 02:58 PM
ldr1ff ldr1ff is offline
Send a message via Yahoo to ldr1ff
1994 caravan 3.3L trany problems...again
I recently replaced the transmission on our 1994 Caravan with the 3.3L V-6. We were able to get recently rebuilt transmission from a 1998 model. The original transmission blew a parking gear through the case.
The newer one has a problem where if it is under about 20 degrees, it will not go into reverse. Drives forward no problem. The person that installed the transmission says that is a seal inside the transmission that when cold will not allow pressure to build up when shifting into reverse.
Anyone ever hear of this? Would it not sound more like the there is a lock out that is not disengaging?
Help Please.
Gregg
Old 02-27-2004, 11:37 PM
trannyman52 trannyman52 is offline
Re-built is a fffffuzzzzzy word!!!! ever herd of an aerosol over-haul?????
if it was RE-BUILT the rev clutch should have had the backing plate re-placed and up-dated "D" rings installed,,,,,Now that you have a delay in rev,,,,I would guess that this was not done, or it was done wrong!!!
Old 02-29-2004, 10:43 PM
transmission problems
We got the news yesterday that the reason the transmission was slipping was they failed to put in some additive that the chrysler transmisisons require. They flushed the system and things are fine now.
1999 grand caravan se 3.3L HEATER Tyson_baker Caravan | Voyager 4 01-24-2011 03:24 PM
1994 Caravan 3.3, starts and dies bigj-dog Caravan | Voyager 3 08-26-2007 06:13 PM
1994 Caravan 3.3 Won't stay running bigj-dog Caravan | Voyager 3 08-20-2007 11:15 PM
1998 Caravan 3.3L Timing Cover Replacement delahuerta Caravan | Voyager 0 05-08-2004 02:04 AM
1992 Dodge grand caravan 3.3L won't start jimsparky Caravan | Voyager 0 02-05-2004 05:21 PM
