Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-24-2004, 01:09 PM
nicang nicang is offline
'96 Sunfire cranks in park but will not start
I have been having problems starting the car. While in park, the engine cranks but will not start. Move the shifter into neutral and the car starts but stalls when I move the shifter back into park. If I start the car in neutral, I can shift into drive and it will continue to run but will stall if moved into park or reverse. This seems to happens after the car is driven about 10 or 15 miles. After the car sits for several hours, it can be started in park.
This has happend about 4 times over the last month or so. I have taken the car into the Pontiac garage but they can not find the problem.
Any suggestions?
Old 03-06-2004, 02:23 PM
spitfire888888 spitfire888888 is offline
no start
ask them if they checked the crank sensor
Old 03-07-2004, 07:29 AM
Re: '96 Sunfire cranks in park but will not start
Thanks - I did take the car to another garage before the pontiac garage where they were able to determine that it could possibly be the crank sensor but suggested that it might not be the problem.
Can you explain why you think it is the crank sensor so that I can contact them to discuss.
Thanks for your help.
Old 03-08-2004, 08:53 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
make sure they properly test the sensor because they are pricey. Also this is one of those things it might be wise to go to the dealer. I replaced one in my car and i called every auto parts place, and the dealer was the cheapest, for the part itself.
97' Intrepid, turns over but will not start. KeithJK Intrepid 1 09-18-2010 11:54 PM
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
2001 Pontiac Grand Am SE 3.4L V-6 Will Crank Over But Will Not Start Carla_in_Kentucky Grand AM 11 09-04-2009 10:02 AM
99 Taurus cranks strong but will not start. ksas025 Taurus | Taurus Wagon 6 10-25-2006 08:32 PM
2000 venture cranks over but will not start tlawtda Venture 2 12-11-2004 08:11 PM
