Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 02-24-2004, 01:04 PM
pistolpete76 pistolpete76 is offline
what is the stock compression ratio for a 92 nissan pick up with the ka 2.4 engine
we would just like the standard compression ratio for the 2.4L engine in a 92 nissan pickup if someone has it, that would be cool
Old 02-25-2004, 09:38 AM
Will2 Will2 is offline
Re: what is the stock compression ratio for a 92 nissan pick up with the ka 2.4 engine
I can't give you the ratio but the compression on the KA24E=192 psi(standard)142 psi( min).NAPS-Z(Z24)81 to 89=171psi standard 128psi Min.
Old 02-25-2004, 02:14 PM
thanks man, i will see if that will work
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 02:56 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
Stock Compression Ratio for the '02 4.0L? Kuhn Wrangler 1 08-19-2007 06:34 AM
Equipment to Measure Compression Ratio for Diesel Engines dollar Engineering/ Technical 1 08-14-2004 09:15 PM
Compression ratio for the toda A,B,C & D tegdc2r Integra 0 06-19-2003 09:22 PM
