Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-24-2004, 09:46 AM
Ca6139uY Ca6139uY is offline
getting rx7-fc s5
okies i'm looking at getting rx7 series 5 turbo....
can some one tell mi what r the good and bad things abt the car??
also what to look at wen buying like the problem that fc have most?
what kinda question should i ask??
bye
Old 02-24-2004, 02:05 PM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
Re: getting rx7-fc s5
Well the good things about the car is that it's rare and has a unique factor to it. It makes 202 hp stock and looks great. The bad part is first finding a decent one in the first place. The engine being that it is a turbo will not last as long as a n/a engine. It takes only premium gas and needs oil changes I'd say every 2500 miles at least. Turbos are harder on the oil so smaller intervals on oil changes are the best idea. The FC's could always use a better cooling system from what I've learned and the grounds on the car aren't the greatest so redoing those at some point wouldn't a bad idea. When you go to buy one the visual inspection is important especially under the car. There you will find the leaks and frame damage which are the worst to fix. Finally if you really wanted to you could take the intake pipe off the turbo and spin the turbine. It should spin freely. Also you could try wobbling it to see if the shaft has to much play. A little play is normal.
Old 02-25-2004, 07:24 AM
2500 miles??? wot that in km???
bye
Old 02-25-2004, 04:25 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Check ALL hoses. Check the manifold and turbo housing for cracks. How many miles/kilometers are on the car? Do a compression test. Most of all, test drive!
Old 02-25-2004, 09:02 PM
dayna240sx's Avatar
dayna240sx dayna240sx is offline
Banned
Send a message via AIM to dayna240sx
I hate people that can't spell.
Old 02-25-2004, 10:59 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
clutch goes out between 80-100k miles usually (mine went at 102k) turbo engines are less reliabe, so it would be a good idea to rebuild it(will save you money in the long run) umm... all I got for now... oh yea, check all switches and lights and what not cuz the wiring and sodering on the FC's is pretty pathetic. thats all I got right now
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 02-26-2004, 02:49 AM
ok thx
bye
