Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-24-2004, 08:47 AM
kevinorhoades kevinorhoades is offline
2nd gen clock fix?
Can the clock on the 2nd gen (early 86 to 87.5) be fixed, or does the whole warning assembly have to be replaced?
Old 02-24-2004, 12:46 PM
ShortyDTP's Avatar
ShortyDTP ShortyDTP is offline
Send a message via AIM to ShortyDTP Send a message via MSN to ShortyDTP
Re: 2nd gen clock fix?
What's wrong with it?
HOLESHOT PERFORMANCE
91 Laser Rs 471 whp at 22psi pump scm-6152e
98 Eclipse GST 11.4 @ 121mph Stock T25/nitrous
Jose Mendoza
Old 03-24-2004, 12:01 AM
MDKacic MDKacic is offline
Post 2nd Gen Clock Fix
The most likely fix for your clock is to re-solder the pins, that connect to the harness. If you look at the pins where they meet the circuit board you will most likely see a tiny line that goes all around the solder on the pin. Re-solder those pins and you should have a clock that acually works.
Old 03-24-2004, 04:18 AM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
mine always cuts out and resets randomly
Old 03-24-2004, 10:50 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
mine got reset when my cd player got put in, and now I can't change the minutes, only the hours, so my clock is 35 min. slow
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 03-24-2004, 09:21 PM
Steel's Avatar
Steel Steel is offline
Re: Re: 2nd gen clock fix?
hmm... why dont you wait till you're on the hour, disconnect the battery, reconnect, then set it to the proper hour?
