Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-24-2004, 01:40 AM
formby formby is offline
Exclamation b18a w/ b16a auto tranny go turbo?
i have stock rebuilt 92 ls (pistons rings head) b16 automatic tranny. i am in the market for a quick spooling turbo to run 6-12 psi on stock internals. what do you guys think...good idea...?
Old 02-24-2004, 05:16 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: automatic ls go turbo?
6 psi...doable
12 psi non IC'ed...goodbye auto tranny/engine
6psi should be good enough for you to work with. 12 psi you would need stronger internals to handle the boost.
I suggest if you want to go turbo, and want to get the most out of it. Drop the engine, and mod the internals, get that all set. Then send in a turbo and you can boost your heart out.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-24-2004, 10:10 AM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
i would not run over 8 psi. we just finished a 99 ls auto teg for a customer. i did a drag manifold, tnetics TO4-E 54 trim, 2.5" down pipe, drag FMIC, apexi S-afc, RC 440cc injectors. the car runs great and spools nice. we will build a engine for this customer out of the car and then when it is done we will swap the built one into the car. since we were going to build an engine for him we went with the to4, for a stock engine i would go with a T3/T4 turbo. there are many variants of the t3/t4 turbos your local tuner shop should be able to help you properly size the turbo for your application, but don't forget what your future plans may be, and include them in your sizing.
Old 02-24-2004, 12:02 PM
I heard that this combo of tranny and motor is a good app for turbo since you can boost an ls up too 12 psi and, with the b16 auto tranny you get longer gears, also with an auto you dont get miss shifts and the turbo /engine last longer. is this true.
Old 02-24-2004, 03:09 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Pre-deationation will kill a motor... boost won't. Intercool it and put alcohol injection on it.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-24-2004, 05:45 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
You should be an alcohol injection salesman! hah hah seriously man! I was just wondering though, why dont more people use alcohol injection?
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-25-2004, 10:37 AM
TEAM KLR's Avatar
boost will kill these hondas. the alcohol injection is a great idea! but even with no (0) detonation and perfect tuning the ring landings will still break off when exposed to boost for a period of time. just not strong enough and were not designed to handle it.
the auto tranny is great for going fast in a straight line. make no mistake though, you will tear it out and will need to be prepared to fix whatever breaks in it. my guess is the torque converter or the clutch packs will go. don't know yet, we will see on my customer's car. i will let you guys know when it does, what breaks, and what i did to fix it.
Old 02-25-2004, 02:00 PM
Hypsi87's Avatar
Re: Re: automatic ls go turbo?
I just beleve in it that much. my car ran a 13.6 @104 MPH and all I did was put an alky kit on the car and my car ran a [email protected] MPH it allowed me to run that much more boost.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 02-25-2004, 10:37 PM
what and how much is it?
Old 02-26-2004, 08:32 AM
Hypsi87's Avatar
Here is a link. Ok let me re phrase my last post, the acohol directly did not help me. The alcohol just let me run more boost on pump gas. Without it, my car could run 15-16 PSI on 93. Now I can run 24 on pump gas with zero deationation.
http://www.rjcracing.com/SMC_Alcohol...injection.html
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
