Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 02-23-2004, 10:23 PM
Turboaddict's Avatar
Turboaddict Turboaddict is offline
89 maxima vg30e map or maf?
I think I got the engine code right. it's a 3L pushrod. does it use maf or map? are they hard to turbocharge?
marcus
Turbo grand prix
3.1L v6
3660lb with driver
9.42 in the 1/8th
mods in progress:
trans rated for 350hp
T3 instead of T25
Old 02-24-2004, 10:27 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: 89 maxima vg30e map or maf?
mass airflow. and the 300zx turbo is a vg30de so that probably won't be too terribly hard to turbo. if it's the sohc version it'll have lower compression pistons which should make it that much easier to run higher boost without damaging your internals. you may wanna swap in TT injectors.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
2002 map light replacement chevyn0va1 Caravan | Voyager 0 10-06-2010 08:50 AM
MAP Sensor, very very strange! SebOber Grand Cherokee | Grand Cherokee SRT8 3 03-28-2010 05:02 PM
98 explorer, bad idle and rough start --MAP, MAF? PBFreeland Explorer | Explorer Sport Trac 15 02-09-2010 09:56 PM
HELP P034 MAP/MAF Too Low 1994 Trans Am asassine F-Body Problem Diagnosis 0 10-01-2007 08:59 PM
1993 Ford Ranger MAP/MAF sensor DSMNerd6889 Ranger | Courier 1 03-18-2005 03:41 PM
