Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 02-23-2004, 09:18 PM
Yellow 944 Yellow 944 is offline
944 Starting Problems (Cam Belt?)
I have a 1984 944 (non-turbo) and have a engine starting problem. The car was running fine and started running rough one evening pulling in the driveway. When I went to restart it a while later, it acted like a vehicle that had spun the timing belt. The engine turns over easily, almost faster than it normally would. I checked and the starter is turning over the engine, and after pulling off the distributor cap, is also still turning the cam. I have fire to the plugs also. Is it possible that the cam belt jumped time and would it make the engine turn over like I stated earlier? I am a bit perplexed on this one. Or is there something else I am overlooking here.
Old 03-12-2004, 07:11 AM
JJB924S JJB924S is offline
944s are interference engines, when the timing belt skips or breaks the pistons can hit the valves and bend them. If they get bent, the won't seat properly and no compression. This could be why it seems to be spinning faster, no resistance from the compression.
JJ
Old 03-18-2004, 08:07 PM
Some1else's Avatar
Some1else Some1else is offline
Re: 944 Starting Problems (Cam Belt?)
First, STOP turning it over!!!!!
Next you will want to pull the covers off the timing belt, balance shaft. You will need a larger 21-25 mm combo wrench, sorry, my car is at work, and I can't remember the size!. You will want to turn the crankshaft slowly till you can see the TDC marks. You should be able to tell from that if you slipped your timing belt.
For more info, go here!
http://www.clarks-garage.com
If you did break, or slip your timing belt, you are not going to be happy! Sorry!
85 Porsche 944 electrical problems! stain 924/944/968 0 08-19-2010 09:30 PM
98 Cherokee Starting Problems cdmonday Cherokee 4 01-22-2010 11:13 AM
98 Cherokee Starting Problems cdmonday Cherokee 1 01-21-2010 07:08 AM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
starting problem (timing belt?) rruddfan21 Metro 18 06-12-2004 09:04 AM
