Old 02-23-2004, 04:05 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
really high oil pressure
my oil pressure goes to 80 and will keep climbing if i don't let off the gas, thats when im driving it nicely. what causes oil pressure to go to high? and my oil is milky as hell, i just changed the head gasket, so does that mean that the head studs got loose or something?
Old 02-24-2004, 09:19 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
If your oil looks milky I would say that there is coolant getting into it. If you just changed the hg, then more than likely it was an installation error. Did you torque bolts to facotry spec in correct order because that is very important. Also did you make sure that the gasket mating surfaces were very clean?
Old 02-24-2004, 10:43 PM
Re: really high oil pressure
i just reinstalled the whole head again. this time i cleaned the surface a lot, and it is torqued down to factory specs, with the pattern. im going to finish the install tomorrow, so hopefully i did everything right. if i did is this going to fix the high oil pressure problem?
Old 02-25-2004, 10:31 AM
Re: Re: really high oil pressure
Honestly, I have never head of an oil pressure issue relating with a hg. I suppose it is possible, I have seen stranger things. Let us know what happens with the oil and the pressure. Did you use a new gasket? You usually dont want to reuse them becuase they get crushed once you put them on once.
Old 02-26-2004, 12:55 AM
i reinstalled everything, i don't think theres any coolant in the oil anymore, but theres a lot of smoke comming form breather hole. and it idles like crap and sometimes itll stall. the timing is right. i was boosting 9psi on a stock ls. what could have broken?
Old 02-26-2004, 09:14 AM
Faulty PCV system or bad piston rings.
Old 02-27-2004, 12:47 AM
SenseiAccord SenseiAccord is offline
what would happen if u leave ur oil pressure running high? Dont kno much about that stuff and i would like to know. thanx ppl
Old 02-27-2004, 09:15 AM
Did it fix your oil pressure problem?
Old 02-27-2004, 09:11 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
if you got the head gasket on upside down then it could raise oil pressure and starve your head for oil.... the holes in it are slightly off center....... very bad thing to do.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
