Old 02-23-2004, 03:37 PM
JOnEB4EvR JOnEB4EvR is offline
Send a message via Yahoo to JOnEB4EvR
Crushed/Uncrushed BOV...???
How can you tell? I bought a 91 eclipse turbo, and I dunno how to tell if the BOV is crushed or not... and if its not, should i leave it alone?
2003 Ford Focus ZTS
Old 02-23-2004, 10:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Crushed/Uncrushed BOV...???
If its crushed the nipple for the vac line, while still coming out of the BOV at a proper 90 degree angle, will rest on the rim of the canister. That is in fact the getto way to crush it. The correct way is to use a mighty vac or similar and crush it just enouhg so it takes 18-19" of vacuum to just crack the valve off the seat.
No reason not to crush it. Usually helps. I've never seen it hurt anything. Might as well do it if you are running more than say 15 psi or so.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-16-2004, 11:44 AM
Hotshot8792 Hotshot8792 is offline
does crushing the blow off valve make it sound any different?
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 05-16-2004, 12:27 PM
AF - Advisor
Nope. Not until you crush it mroe than I recomended above at least. At 20" it starts to get fluttery.
Kevin Jewer
