Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-23-2004, 03:14 PM
Daily6621 Daily6621 is offline
Unhappy seat belt motors
My seat belt motors on each side is binding and draining the battery. Does go out alot in these cars? And how to stop the motors from draining the battery? 1991 Ford thunderbird
Old 02-23-2004, 06:44 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: seat belt motors
You can just unplug them from the harness. Or check to see what is causing them to bind up if its an easy fix then that will take care of it.
Old 03-20-2004, 11:41 AM
carlton31204 carlton31204 is offline
Seat belt motor
I am having a problem locating and replacing the seat belt motor on the drivers side. If nothing else is there a way to manually lock seat belt slide in locked position?
Old 03-20-2004, 04:27 PM
fordforlife's Avatar
fordforlife fordforlife is offline
mine make noise when they are closing, not a light hum, nice loud noise, does that mean the motor is going out? or can u grease the track to fix it? ive never had motorized seat belts before, so i dont know much about them. sorry i used your thread, but i figured it fit.
Old 03-20-2004, 11:45 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Carlton31204, the seatbelt motor is behind the B pillar below the quarter window.
fordforlife, it is possible to lube the track to make it slide more easily. The most effective way is to pull the whole track but this isn't necessarily easy. A quick fix would be to spray some white lithium grease in there.
Daily6621, not sure what is causing your problem. It is possible that the belts are binding in the track and not allowing full forward travel. If that is the case, the motor is still trying to push. I have a similar issue on one of my '93s. Every now and then when I open the door the seat belt will only travel about 1 inch and quit. (this is when I'm in the car, it's running, and I want to get out.) If I close the door and open it again, all works well. Haven't been motivated to find out why. It is possible there is a dead spot in the motor, but that is just a guess at this point.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 03-21-2004, 11:22 AM
thx dude. the only white lithium i can find is in a grease tube, like silicon, the autozone dude showed me some other stuff thats in a spray can that he sadi works just as good, but i forgot the name, i'll have to get back to u on that. But its like a silver color, almost metallic looking.
Old 03-22-2004, 11:43 PM
Re: Re: seat belt motors
i found the spray white lithium, it worked like a charm, thx man!
Old 03-24-2004, 06:54 AM
Glad I could help.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
