Old 02-23-2004, 01:54 PM
Snowbder4life Snowbder4life is offline
Taking off door panels
I just got my del sol a week ago and I know nothing about cars, so sorry if this seems stupid and easy...The door handle on the inside doesn't stay in place where it's suppose to be, it protruds out...and you can't open the door from the inside. I was wondering if there is anything i can do to fix this?? and if so how do i take off the door panels??? Also if anyone knows places online were you can by interior parts let me know...Thanx
Old 02-23-2004, 04:24 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Taking off door panels
The door latch release rods I believe have to be aligned correctly when you install the door handle. I don't think anything's broken, just not put back together correctly.
As for taking the door panel off, I think it's just a screw under a screw cover on the door handle, one up by where it meets the dash, maybe one on the door panel toward the rear near the latch, and then I think it's just clips holding it on from there - just pry it off. I've never taken mine off personally, so can't speak from first-hand esxperience.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 02-23-2004, 07:51 PM
Werdna Werdna is offline
Does your handle looook like this?
http://www.teamdelsolwa.com/howto/handle.htm
Old 02-23-2004, 09:33 PM
Good point there. I completely forgot Team Sol WA had something on this. If you don't want to mess with "repairing" it, I think I've seen a few brand new OEM Del Sol handles on eBay for $25.
Old 02-23-2004, 10:41 PM
If it's like the how to on teamsolwa then it's just that the rod has fallen outta it's hole... just unscrew that one screw and push it back in..it happened to me once and it hasn't reoccured.
Old 02-24-2004, 03:56 PM
thanks for the help you guys were right...it was that the spring just fell out of a small hole...thanx again...If anyone knows were i can get info on how to install speakers, let me know
Old 02-24-2004, 08:14 PM
Uh what? Installing speakers is super easy in the Sol..
Old 02-24-2004, 11:05 PM
Pull off your front speaker grills. They just pop off. Done. You have access to your speakers.
For the rear, just pull off the center panel, unscrew the two screws on each speaker cover, and pull - just clips holding them on from there. Done. You have access to the rear speakers.
Old 02-24-2004, 11:19 PM
Re: Re: Taking off door panels
Like I said.. easy!
once you do it once. you can rip them all out in 10 mins...or less I pop them out for fun sometimes!
