Old 02-23-2004, 11:55 AM
Euroguy026 Euroguy026 is offline
Spark Plug Questions
I pulled one off and the terminal tears out of the boot and stays on the plug. So I gently remove the rest, twisting the rubber boot as I pull, every damn terminal on all 6 boots rips off. Is there any reason for this? They were bosch plugs. that ripped so i got Borg N Wagner Wires that were 40 Bucks the good ones, and i put them on but im afraid when i wanna change the plugs they are gonna rip off any reason? I have the wires kinda bunched up together with a zip tie. Could that be it?
Beware My Euro May Be After U!
www.cardomain.com/id/euroguy026
The LUMINATOR LIVES On
Intimidator (#3 Nascar) + Lumina = Luminator
Old 02-23-2004, 12:34 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: Spark Plug Questions
the wires came apart from thier age...they should be fine. The zip ties though are not fine..the wires should be isolated from each other to help prevent crossfiring and arcing.. go to the dealership or the salvage yard and get the original wire holders...
There is also a tool called a sparkplug wire puller...it allows you to grab the boot and not the wire.
Old 02-23-2004, 01:53 PM
Well the plug wires were new and they broke, i have the sperator i just didnt put them back in lol
Old 02-24-2004, 07:37 AM
i put plastic tubing around the wires but i didnt do the back three yet i need more plastic stuff, but im doing this so there isnt any misfire
Old 02-24-2004, 02:43 PM
OldCarGuy OldCarGuy is offline
Those new plug wires came with insulator grease that you needed to put into the end of both the coil boot and plug boot before you put them on. If you negect to do this it allows moisture to get into the coil boot and rust will cause it to misfire.
Old 02-24-2004, 02:46 PM
one other thing is that the grease they supplied make it alot easier to put them on and get them off if you need to without breaking the wire loose. Grip the boot and turn before pulling. After it turns freely then pull while turning. It's much easier and you won't break it. Oh yeah use the grease.
Old 02-24-2004, 06:10 PM
JERKY420 JERKY420 is offline
just to let you know I've been working on 3.1 and 2.8 engines for quit a few years and the connectors always just seem to come off it doesn't matter how old or new they are or how much grease you put on them they just tear apart it is a fact of life there is no tool available to stop this. The best you can do if you don't want to replace the wires every time is to put them back together by pushing the wire through the boot and using a pliers or needlenose to put the connector back on the wire. I've noticed it doesn't happen to all the wires all the time, it is just a fact of life they will come apart.
Old 02-24-2004, 08:06 PM
I did put grease on the new ones hehe im trying to take every precaution, okies thankx anyway
Old 02-25-2004, 02:40 AM
I didn't say that the grease is a bad thing, it isn't, it is good to put grease on the boots it does seal them from moisture, but that will not stop them from coming apart.
Old 02-26-2004, 08:00 AM
Hey, why is it that the wires break all the time, i have 3 cars before this and this never happened? Why does this happen with this v6 engine
