Old 02-23-2004, 11:22 AM
mint567 mint567 is offline
Eclipse Temp. Fluxuates
My eclipse with no mods just stock, the temperature fluxuates when i am going down the highway or idling. It doesn't matter. It has been checked by a couple of local mechanics. None of them could find a problem. They say that they checked the thermistat and everything. The fluxuation continues to go on. It never stays hot. It will run normal at half way between H/C. then it will go up 3/4 to hot, then drop back down after about 30 seconds or so. It doesnt matter if the weather is hot or cold. It does it no matter what. Any ideas suggestions? THanks.
Old 02-23-2004, 12:07 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Eclipse Temp. Fluxuates
check to make sure the overflow tank is secured and the hoses are on where they should be. i had the same problem and my tank was completly gone [just dissapeared one day], but i was told it was pressure differences giving off wierd readings. hope that helps...
Old 02-23-2004, 12:40 PM
Where might I find this tank at?
Old 02-23-2004, 01:42 PM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
1. air in the cooling system
2. temperature sending unit out of range.
3. thermostat malfunctioning
4. fan temperature switch out of range
Old 02-23-2004, 03:09 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
It should be near the Power stearing belt, lower left corner of engine bay. It is a yellowish color.
Make sure it is not leaking, mine was not properly mounted and the PS belt ate the side of it.
For Sale 98 Eclipse GS, 5 spd
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
