Old 02-23-2004, 02:25 AM
Tough Blazie Tough Blazie is offline
Interior Lights won't shut off even though the switch is OFF and DOORS are fully shut
how do the hell I turn the interior lights off??? I probably think the hatch's loose?
Old 02-26-2004, 02:39 PM
Basssed Basssed is offline
Re: Interior Lights won't shut off even though the switch is OFF and DOORS are fully shut
This will sound crazy but remove your cigarette lighter. Check the fuse panel for a blown fuse. If that is it replace the lighter. It happened on my S-10 I found it by accident. Lighter shorted out and caused some weird problems
Old 02-27-2004, 12:36 AM
amac209 amac209 is offline
Send a message via MSN to amac209
is the dash dimmer cranked up??? if it isn't check the pin switches lube them up and slam the doors a few times.
Old 02-28-2004, 02:54 PM
TriAxis TriAxis is offline
I had this small problem with my 95 Blazer. It turned out that the rear
window, wasn't shutting tight with the tailgate. Make sure this is shut tight. If it is try manually pushing in the rear button with your finger, to see if this shuts off the light.
Old 03-02-2004, 09:11 AM
frankjc frankjc is offline
I have that same problem every so often.
I have found that pushing the door switches by hand several times each makes it stop.
The other thing that happens, is that when I shut the car off, the radio shuts off immediately, instead of staying on fo a minute, because the computer thinks the door is open.
Old 03-02-2004, 10:25 AM
kentuc794 kentuc794 is offline
Send a message via AIM to kentuc794 Send a message via MSN to kentuc794 Send a message via Yahoo to kentuc794
I had the same problem as Triaxis with my rear window. I took it to a dealer and they found that my window was not shutting all the way. They lube my latch and button and everything has worked great since.....
