Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-22-2004, 11:29 PM
bassman bassman is offline
type2 tune up cost
how much should i pay for a type 2 tune up for my '95 318i?
to my knowledge, it has never had a tune up
it has 120 000+ miles on it
the guy said it will need type 2 because of the milage
Old 02-23-2004, 12:35 PM
323imankiks's Avatar
323imankiks 323imankiks is offline
Inspection 2 services are expesive it depends were you take it in my area there is only one dealership and they charge over 700 dollars. Independent shop charge around 500 or less. If you have some knowledge about cars You can do it yourself oil change and filter are part of it inspecting under the car for any visible damage to parts possible new sparplugs fuel filter. I personally think its a waste of money for them to just "inspect" it and then tell you there is a problem then charge you on top of that to fix it. If you have friends that have a little know how ask them to help you to do the basics oil filter and maybe plugs and air filter, fuel filter, etc
"What happens here stays here" LAS VEGAS
Old 02-23-2004, 03:10 PM
Skycity_BMW's Avatar
Skycity_BMW Skycity_BMW is offline
Send a message via Yahoo to Skycity_BMW
Inspection Help
This is a list of whats done on an InspectionII
Undercarriage
Change engine oil and filter oil while engine is at normal operation temperature.
Check transmission for leaks.
Check rear axle for leaks.
Visually check fuel tank, lines, and connections for leaks.
Check condition, position, and mounting of exhaust system. Examine for leaks.
Check power steering system for leaks.
Check overall thickness of front and rear disc brake pads.
Examine brake disc surfaces.
Clean brake pad contact points in calipers.
Grease wheel center hubs.
Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
Check front control arm bushing for wear.
Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
Check for free movement of the parking brake cables. Adjust parking brake if necessary.
Check all tire pressures (including spare). Correct if necessary.
Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Check thickness of parking brake linings.
Half-shafts; check for leaks at flexible boots.
Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
Read out diagnostic system
Check engine cooling system/heater hose connections for leaks.
Check coolant level and antifreeze protection level; add coolant if necessary.
Check level of brake and clutch fluid in reservoir; add fluid if required.
Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
Check air conditioner for operation.
Reset Service Indicator.
Replace spark plugs.
Replace intake air cleaner element.
Body/Electrical Equipment
Check battery electrolyte level and add distilled water if required.
Perform batter load test.
Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
Check instrument panel and dashboard illumination.
Check all warning/indicator lights, check control.
Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
Check wiper and washer system(s); wiper blades, washer jet positions.
Check condition and function of safety belts.
Oil hood, trunk/tailgate, and door hinges.
Grease hood, trunk/tailgate and door latches. Check operation of all latches.
Check central locking/double lock.
Replace microfilter or Acc Cabin Filter.
Check heater/air conditioner blower, rear window defogger.
Check rear view mirrors
Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Good Luck ! ! !
Skycity_BMW
built RB25det E-manage Ultimate Tuning... need a little help Modern_Performance Technical 0 07-31-2010 11:25 AM
Estimated Labor Costs/Please Respond!!! java_junkie Nubira 3 12-28-2009 08:09 PM
can someone help me tune up my 2005 Mitsubishi Lancer Ralliart mike9000 Lancer 5 12-10-2009 01:40 PM
Extreme Tuning Car Show Tijuana 2009 Advanguard Car Videos 0 06-04-2009 02:27 PM
tune-up costs tanika 3 Series 5 06-24-2004 08:38 AM
