Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 02-22-2004, 09:16 PM
elad elad is offline
loss of oil pressure
Hi everyone, newbie to these forums. Here's the problem, I've got a 1994, 5.0 van. when I first start it the oil pressure is at 50psi(cold start) after dropping off high idle it drops to about 32psi and about 10 minutes later drops to 0psi any throughs, oh yeah, no noise in motor at startup.
Old 02-22-2004, 11:26 PM
ModMech's Avatar
ModMech ModMech is offline
Re: loss of oil pressure
You must have a mechanical gauge, yes? Because the factory "gauge" is switch operated, it's not a pressure gauge at all. It reads either Zero, or about 40-45% full scale.
If you are referring to the factory gauge, replace the oil pressure switch.
Old 02-24-2004, 09:02 AM
Sorry, about not responding in a swift manner, was out of town for a couple days. Thank you for your input. is a oil pressure switch the same as an oil senting unit?, I disconnected the stock oil pressure gauge and connected a different one to get my readings. Thinking it might be the gauge. It's not.
Old 03-05-2004, 10:26 AM
ModMech's Avatar
No it's not the same exactly. A sender by definition is variable, a switch is not variable they are either on or off. The oil pressure switch is in the standard "sender" location by the oil filter as always. It's just no longer a real sender. Replace that, and your "gauge" should read correctly again.
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
