Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 02-22-2004, 12:31 AM
youngmanvr4 youngmanvr4 is offline
Lookin at a RX-7
Hey...i'm new to RX-7's.So i need help.I'm looking at getting a 93-95 RX-7.If i do...i will mod it up and stuff.Like singel turbo and every thing that gos along with it.But my question is.When you say street/mild port and bigger apex seals.What are you talking about?Also...is there anysites i can do some research on RX-7's at?And anygood places to buy parts at?Thanks for your help.Sorry that i'm a newbi.
Old 02-22-2004, 02:11 AM
RB25240kouki's Avatar
RB25240kouki RB25240kouki is offline
Send a message via AIM to RB25240kouki
Ok Ill do my best to explain a little. Hopfully someone else will post to back up what Im saying or correct me. First of a street port is when you have the intake and/or exaust ports on the rotor housings ground out to make them bigger so they flow more. Its very similar to porting heads on a piston motor execpt porting a rotary has the same affect as changing cams on a piston motor. If youve ever heard a Mustang or other "muscle car" idle very rough its because they have a different, more argressive cam. On a rotary a mild/stage 1 port is only making the ports a little larger and longer so as to keep it streetable (idle at low revs and pass emisions). Apex seals are the seal between the rotor and the rotor housing and are comprable to piston rings. Getting bigger ones (stock are 2mm and bigger are 3mm) is to make the seals last longer (espically for turbo motors). Not so knowlageable on FDs but I think your single turbo idea is in the right direction. Im sure others on this fourm can recomend places to buy parts from better than I could. Good luck with getting an FD.
1989 GTUs
JDM Turbo II motor
Custom exuast: gutted pre-cat, high flow 3" cat. Ypipe into two 2.5 inch pipes with N1 sytle cans.
Walbro 255 fuel pump
Pivot headlight controller
More mods to come
Happy Rotoring
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: Lookin at a RX-7
do you yahoo? scratch that, just use google, its the best answer finder in the world
but anyways, porting is making the intake and exhaust ports bigger, yada yada lots of stuff I don't have time to type... I think this might help you http://home.iprimus.com.au/bluey3/portsPage/ports.htm
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
